May 16, 2023, 15:05 |
Dynamic pressure from oscillation airfoil
yuval
Rep Power: 3 |
Hello everyone,
I try to find the efficient way to export data about dynamic pressure in 6 points on the airfoil in transient simulation (Fluent) when the angle of attack changes (using dynamic mesh). I need the data of dynamic pressure for every time steps (in 6 difference points). The only way I thought of at the moment is inefficient, to manually export the dynamic pressure from each time step. It is important to note that I have over 60000 time steps. Thanks for the help |
May 17, 2023, 02:18 |
Rep Power: 17 |
The best thing to do is set up monitor points and have these saved to a file. But you would have to rerun the simulation.
The other approach would be to use a Scheme or, in a newer version of Fluent, Python script to load the data file and mine the data. Depending on the file size this could be very time consuming. |
May 17, 2023, 03:53 |
#3 | |
yuval
Rep Power: 3 |
May 23, 2023, 03:52 |
mathu
If you want a richer understanding of pressures in flowing fluids, I'd encourage you to study the concept of "stress" in continuum mechanics. The hydrostatic pressure P that we are familiar with is isotropic: that is, it applies the same force/area in all directions, but this is not always the case.
In addition to a hydrostatic pressure, a flowing fluid can also have a "deviatoric" component of stress. This portion is not isotropic, and can accelerate the fluid velocity. pikashow ppsspp emulator Last edited by salmankhan886111; June 1, 2023 at 05:43. |
postprocessing result pressure in the inlet using simplefoam | rjomega | OpenFOAM Verification & Validation | 0 | March 20, 2022 03:39 |
Problem with restart solution in shape_optimization.py | robyTKD | SU2 Shape Design | 21 | May 29, 2013 10:26 |
pressure oscillation near pressure outlet boundary | kino | Main CFD Forum | 5 | April 13, 2011 12:03 |
Setting dynamic pressure as the inlet BC | ruined | FLUENT | 1 | March 26, 2008 06:30 |
Hydrostatic pressure in 2-phase flow modeling (CFX4.2) | HB &DS | CFX | 0 | January 9, 2000 14:19 |
