Rotating 2 tubes against each other
Old   May 8, 2023, 11:30
Default Rotating 2 tubes against each other
Lea
Aryaala is on a distinguished road
Hello everyone,
i want to rotate 2 tubes that lie in each other. I constructed them in PTC Creo and imported the assembly in Ansys Workbench. I put a torque on the inner tube and fixated the outer tube, so it doesnīt move. I defined the contact conditions but the inner tube doesnīt rotate, when i look at the total deformation or other solution options.
Maybe someone has an idea why my simulation doesnīt work. I watched like every youtube video but i canīt figure out where my mistake is. Unfortunately i canīt upload my simulation here
Thank you in advance
Aryaala is offline   Reply With Quote
Rotating Region - Results EmmTheof84 FLUENT 1 November 21, 2020 16:53
Car external aerodynamic with wheel spinning issue hokhay FloEFD, FloWorks & FloTHERM 2 August 18, 2016 05:23
Rotating ZigZag Bed Pugnax CFX 8 March 8, 2015 18:16
Rotating Impeller Naith FloEFD, FloWorks & FloTHERM 22 November 5, 2012 09:53
Vertical Axis Wind Turbine Rotating Domain Problems TWaung CFX 4 May 1, 2012 04:14
