Geometry of centrifugal pump
Old   May 1, 2023, 13:21
Default Geometry of centrifugal pump
Ahmed
Ahmed Abotayel is on a distinguished road
Hello everyone
I am working on centrifugal pump simulation case, i have just reviewed some previous published simulations of the same case, in some cases i found the inlet pipe extended to the impeller inlet and sometimes i found it extended to the casing body only
What are the factors determine the end of the extension of the inlet pipe?
https://prnt.sc/d_06qDcoQgLm
That is the pump i am trying to simulate, if someone can recommend the shape of geometry of inlet ot will be a great help for me
Ahmed Abotayel is offline   Reply With Quote
Why am I getting negative pressure head of the Centrifugal Pump through CFD? raza48919 FLUENT 6 April 26, 2023 15:11
finding volume flow rate of a centrifugal pump vivjk94 Main CFD Forum 2 July 6, 2022 14:31
Pump power for hoses feeding to nozzles Rob Wilk Main CFD Forum 0 February 24, 2021 10:37
centrifugal pump and centrifugal fan Mangesh Main CFD Forum 3 January 3, 2006 12:21
stator-rotor interaction in the centrifugal pump G.H.Lee Main CFD Forum 4 May 25, 1999 08:33
