How to use PolyFlow to successfully calculate viscoelastic fluid flow |
March 4, 2023, 07:59 |
Jichun Zhao
Dear members,
I'm new here and hope the first question to be compounded with the question specification. Problem description: As long as I use ANSYS Polyflow to calculate viscoelastic models (PTT、Oldroyd B、Doi-Edwards), I get an error like the following: "Divergence detected for field S_EVSS__1: iterations cancelled by Expert System Divergence detected for field D_EVSS: iterations cancelled by Expert System" "Divergence of influent solver occurred !" Although I modified the model parameters and meshes to make it as simple as possible. Sincerely hope to get any help from everyone about this software. Thanks! |
polyflow;vsicoelastic; |
unable to run dynamic mesh(6dof) and wave UDF | shedo | Fluent UDF and Scheme Programming | 0 | July 1, 2022 18:22 |
Multiphase flow - incorrect velocity on inlet | Mike_Tom | CFX | 6 | September 29, 2016 02:27 |
Want Impeller Driven Fluid Flow: What Inlet and Outlet BC to use for Centrifugal Pump | Zev Xavier | FLUENT | 3 | May 9, 2016 07:42 |
two fluid, volumetric/mass flow rate at different volume fractions | Veronique Pe | CFX | 2 | November 26, 2014 06:30 |
Viscoelastic flow in rotor-stator @ POLYFLOW | Sumeshen | FLUENT | 1 | August 5, 2013 04:07 |
