Consecutive Named Selections of multiple similar faces
Old   January 30, 2023, 13:05
Question Consecutive Named Selections of multiple similar faces
Harry
HBowen is on a distinguished road
I'm running simulations of radiators (fluid side only). Each radiator has more than 100 tubes, and I need to calculate the pressure drops through each tube, as well as the individual flow rates.
Until now, I have put faces on each end of every tube (set as interior boundary types) and created named selections for each tube separately. I'm looking for a reliable way to streamline this process, as it's quite laborious.
Is there a way to automate the naming of multiple similar faces, such that they are named consecutively and not together? ie. I wish to name them inlet_1, inlet_2, inlet_3... and not just 'inlets'.
Alternatively, is there a better way of calculating the pressure drops and flow rates through each tube without creating and naming these faces?
HBowen is offline   Reply With Quote
Old   February 1, 2023, 10:05
Erik
evcelica is on a distinguished road
I use CFX. Instead of starting off with a full model of all the tubes. If you use mesh transformations in CFX-Pre to create a pattern of tubes from an original, they will be consecutively copied and named as you describe.
evcelica is offline   Reply With Quote
Old   February 1, 2023, 10:08
Harry
Would this work if the tubes are not all the same in length? Or would the tubes need to be identical to achieve this?
Thank you for your reply.
Old   February 2, 2023, 12:39
Erik
Mesh Transformations usually copy the mesh, but you can also scale them non-uniformly. you may need to use several mesh transformation steps to build your geometry. It is hard to give advice on the best way to achieve this without seeing the geometry. I'd advise you to test out mesh transformations to see how they work and how the naming convention numbers everything.
automation, fluent, meshing, named selections
[snappyHexMesh] Error snappyhexmesh - Multiple outside loops avinashjagdale OpenFOAM Meshing & Mesh Conversion 53 March 8, 2019 10:42
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 19:57
[OpenFOAM.org] OF2.3.1 + OS13.2 - Trying to use the dummy Pstream library aylalisa OpenFOAM Installation 23 June 15, 2015 15:49
foam-extend_3.1 decompose and pyfoam warning shipman OpenFOAM 3 July 24, 2014 09:14
Cluster ID's not contiguous in compute-nodes domain. ??? Shogan FLUENT 1 May 28, 2014 16:03
