Obtained coefficients that were significantly different from the author's wind tunnel
Old   January 12, 2023, 12:54
Talking Obtained coefficients that were significantly different from the author's wind tunnel
Renz
Renz101 is on a distinguished road
Hello, I'm new to this software; could you possibly assist me in finishing my undergraduate thesis? This is the only activity I must complete in order for me to graduate. I am currently attempting to obtain lift and drag coefficients @ 100k Reynolds number from my CFD 2D Simulation using Fluent ANSYS. However, I obtained significantly different coefficients from the author's wind tunnel test results (for validation). I used the following setup:
  1. Viscous Model: k-omega – SST model, as shown in Figure1.
  2. Inlet: ****Please see Figure2. This is for 0 angle of attack.
  3. Reference Values – Area is 0.1m^2 with Depth 1m, and Length 0.1m. Left the rest as their default values, as depicted in Figure3.
  4. Solution Method: ****Please see Figure4.
  5. Report Definitions: Drag and Lift settings are shown in Fiugre5.
  6. Residual: Absolute Criteria was set to all 1e-07.
  7. Initialization: Hybrid Initialization.
  8. Run Calculation: Number of Iteration at 1k.
  9. The airfoil’s dimension is 100mm. Density is 1.225 kg/m3. Dynamic Viscosity 1.7894e-05.
////// Everything that I didn’t mention were set to their respective default settings and values //////
\\\ Other figures are uploaded on the reply section because the # of uploaded pictures are limited.\\\\
To vary the angle of attack, the airfoil is positioned horizontally while modifying the flow direction in both the X and Y components using the cosines and sines of radians of the angle of attacks. For example: cos [radian (1°)], and sine [radian (1°)] – I saw this on YOUTUBE. A NO-slip conditions was applied to the airfoil surface.
I am using a rectangular-type domain with structured boundary layer grid around the airfoil and an unstructured grid in the outer domain, as illustrated below in Fig 7. It contains over 52k components in total.
Renz101 is offline   Reply With Quote
Old   January 12, 2023, 12:57
Default Other figures
Renz
Other figures
Old   January 12, 2023, 12:58
Smile Other Figures part 2
Renz
Verification of a Wind Tunnel Experiment JamesR OpenFOAM Verification & Validation 1 August 17, 2023 18:51
[HELP] - About the Numerical Wind Tunnel abing999 FloEFD, FloWorks & FloTHERM 0 September 1, 2022 03:44
Wind Tunnel Blockage question ohma0043 CFX 9 June 17, 2018 20:19
Wind Tunnel Testing Vinnende Main CFD Forum 4 April 13, 2012 16:15
Wind Tunnel Website now online Mike Worthey Main CFD Forum 0 June 6, 2000 03:27
