Ansys aqwa convolution error
Old   January 4, 2023, 08:24
Post Ansys aqwa convolution error
MAI THI LOAN
mailoan2306 is on a distinguished road
Hello everyone,
I am simulating the mooring line with the fish farm system.
During the simulation of the mooring line in irregular waves with irregular wave response. However, I got the error
"CONVOLUTION ERROR. The convolution has failed to calculate a satisfactory fit to the added mass/damping for the structure. This is usually caused by insufficient frequencies or an inadequate frequency range. PLEASE-ENSURE THAT THESE ARE SUFFICIENT "BEFORE" contacting user support. Frequency range for structure should be at least 0.247 to 5.695 rad/sec"
I tried to simulate the system with a range frequency from 0.2 to 0.6 rad/s. But the error still occurred.
I hope to receive a solution from everyone.
Thank you so much in advance.
mailoan2306 is offline   Reply With Quote
Old   March 26, 2023, 14:06
Joshua Cutler
enrjcutl is on a distinguished road
Hi mailoan2306,
Did you manage to find a solution to this problem?
Kind regards
enrjcutl is offline   Reply With Quote
[swak4Foam] swak4foam openfoam 7 installation problem Andrea23 OpenFOAM Community Contributions 1 February 17, 2020 19:11
[OpenFOAM.org] compile error in dynamicMesh and thermophysicalModels libraries NickG OpenFOAM Installation 3 December 30, 2019 01:21
Compile calcMassFlowC aurore OpenFOAM Programming & Development 13 March 23, 2018 08:43
long error when using make-install SU2_AD. tomp1993 SU2 Installation 3 March 17, 2018 07:25
How to get the max value of the whole field waynezw0618 OpenFOAM Running, Solving & CFD 4 June 17, 2008 06:07
