Is ANSYS Suitable For Simulating "Revolving Wings" Rotating 360 Degrees In Airflow?
Old   November 4, 2022, 07:10
Post Is ANSYS Suitable For Simulating "Revolving Wings" Rotating 360 Degrees In Airflow?
Mike P. Dehorne
Mike_Aerodynamics is on a distinguished road
Hello, new member and CFD beginner here.
I want to work on the new problem of Revolving-Wing Wind Turbines which consist of only 1 vertical wing constantly turning 360 degrees around its Y_axis like these guys on Youtube are doing:
https://youtu.be/7hVQ_rVNRUI
https://youtu.be/AMuworVnTNI
I am new to CFD and have not used ANSYS before.
Can ANSYS simulate airflow turning such a vertical wing 360 degrees with lift force and drag around a center shad5?
Is it a suitable CFD solution for this problem?
Thank you for any advice!
Mike_Aerodynamics is offline   Reply With Quote
Old   November 10, 2022, 05:23
Gert-Jan
Gert-Jan will become famous soon enough
I don't know how the wing looks like when standing still, when it is rotating around a fixed axis, than this can be done quite easily.
Gert-Jan is offline   Reply With Quote
Car external aerodynamic with wheel spinning issue hokhay FloEFD, FloWorks & FloTHERM 2 August 18, 2016 05:23
[snappyHexMesh] sHM layer process keeps getting killed MBttR OpenFOAM Meshing & Mesh Conversion 4 August 15, 2016 04:21
Can you help me with a problem in ansys static structural solver? sourabh.porwal Structural Mechanics 0 March 27, 2016 18:07
Ansys SIG$ILL error loth ANSYS 3 December 24, 2015 06:31
snappyhexmesh remove blockmesh geometry philipp1 OpenFOAM Running, Solving & CFD 2 December 12, 2014 11:58
