How to create a tapered 3D wing in Spaceclaim? |
Lucas Pelizzari
Rep Power: 4 ![]() |
I want to create a wing with root chord 1.66m and tip chord 1.33m, with half wingspan 5.235m, with a NACA 4412 as the airfoil.
I tried to import both the points for the root and the tip separately, but this only ended up creating 2 different projects. When I put them both in the same file, it worked, but I can't figure out how to finish it off with the wing surface. If I try to put more than 2 sections in the same file (to maintain the shape of the airfoil along the wingspan), it won't import. What do I do? |
Lucas Pelizzari
I solved it.
I generated both airfoils, tip and root, and closed them in order to make a surface. Then I clicked this ![]() |
spaceclaim |
Pointwise create good mesh on wing suction side, but poor mesh on pressure side | quarkz | Pointwise & Gridgen | 2 | August 31, 2020 23:28 |
How to create OUTPUT parameters in SpaceClaim? | pinkerthoms | ANSYS | 1 | March 3, 2020 04:37 |
Create an airfoil patch in a wing | Bernoulli666 | OpenFOAM Pre-Processing | 0 | May 26, 2017 11:09 |
[snappyHexMesh] Meshing 3D wing (hydrofoil) fails | klausb | OpenFOAM Meshing & Mesh Conversion | 0 | December 28, 2011 14:26 |
Where's the singularity/mesh flaw? | audrich | FLUENT | 3 | August 4, 2009 01:07 |
