Retrieving strain energy from COMBIN39 nonlinear spring element |
August 15, 2022, 12:49 |
Johannes Schneider
Rep Power: 5 |
I use nonlinear springs type COMBIN39 to model contact of a loaded cantilever beam (BEAM188) with stiff ground.
The COMBIN39 elements are evenly distributed along the beam, representing a continous bedding. As long as there is no beam-ground contact, the stiffness of these elements is very small k0 (zero stiffness is not allowed). Initially beam and ground are separated by a distance w*. As soon as the beam touches the ground (w >= w*), there is a change in stiffness k1 >> k0. I can model this nonlinear behaviour with a set of real constants: r,3,0,0,w*,k0,w*+1,k1 I want to read the total strain energy (SENE). To do so i use element-tables which i then sum up: esel,s,ename,,188 etable,sene188,sene ... esel,s,ename,,39 etable,sene39,sene ... allsel ssum The output for sene188 looks fine, but for sene39 it is always zero. From the total potential for a linear spring i know that U = 1/2 k w^2 and thus in this case U = 1/2 k1 (w-w*)^2. From an approximate calculation by hand i know that this is unequal zero. Does anyone know how to retrieve the strain energy from a COMBIN39 element? |
August 18, 2022, 08:27 |
No strain energy available for COMBIN39
Johannes Schneider
Rep Power: 5 |
In table 14.4: Exceptions for Element Energies from the theory reference manual the COMBIN39 is listed and thus no energy is available for this element type.
For this simulation a COMBIN40 element might be suitable. |
ansys, combin39, strain energy |
mesh file for flow over a circular cylinder | Ardalan | Main CFD Forum | 7 | December 15, 2020 13:06 |
[Gmsh] 3D Mesh conversion from gmsh-2.5.0 to OpenFOAM | Ancioi | OpenFOAM Meshing & Mesh Conversion | 17 | January 8, 2019 23:50 |
[Other] Mesh Importing Problem | cuteapathy | ANSYS Meshing & Geometry | 2 | June 24, 2017 05:29 |
Two way Fsi Problem- Non linear problem | kmgraju | CFX | 4 | April 28, 2015 11:15 |
autoPatch error, mesh quality related...? | Alexvader | OpenFOAM | 0 | October 6, 2011 17:57 |
