Ansys Mechanical Supports for Rotating Propeller |
July 31, 2022, 16:14 |
diogenis
Hi!
I am working on an FSI analysis of an aircraft propeller and i am bit confused about the setup of ANSYS Mechanical. I completed the setup and as i am trying to run the simulation (using system coupling) an error appears : | Participant Solution 1 encountered a fatal error. Message: The value of UY | | at node 65052 is 198196613. It is greater than the current limit of | | 1000000 (which can be reset on the NCNV command). This generally indicates | | rigid body motion as a result of an unconstrained model. I wont to ask what type of joint and supports i should provide to the propeller on Ansys Mechanical, so I can solve my model. In general I think that rigid body motion should be alowed by the solver. Thank you in advance for your answers! |
ansys mechanical, joints, propeller, rotating parts, supports |
INTEL or AMD EPYC ROME for ANSYS Mechanical | evcelica | Hardware | 10 | March 25, 2021 16:27 |
Ansys - Electrical power is greater than mechanical power in claw pole alternator | JohnZ34 | ANSYS | 0 | April 10, 2019 19:46 |
How do I find thrust and torque for a propeller in ANSYS Fluent ? | Hayatul_Maruf | FLUENT | 0 | May 14, 2018 01:05 |
Can you help me with a problem in ansys static structural solver? | sourabh.porwal | Structural Mechanics | 0 | March 27, 2016 18:07 |
Ansys mechanical APDL problem. | russogianluca90 | ANSYS | 0 | October 13, 2014 08:38 |
