AnthonyBowers
Rep Power: 6 ![]() |
Hi all,
I am in severe need of help, for I have spent too much time on this issue and am now getting unmotivated. My problem statement is I would like to model a Membrance Gas-Liquid contractor for the removal of a particular species. My issue is I do not understand how to couple domains and allow for the diffusion of species to occur through a membrane or even a solid domain. I do not want to simply put a source term because I want to post-process the flux of the species leaving my primary domain. In the primary domain, I will have a fluid contains the species I want to remove. The species will diffusive radially to the top where it will then permeate through a membrane to then be swept away. I will take any help anyone is to offer. What I have accomplished so far is meshing the domain and making the mesh continuous by the automatic mesh connection group detector. I named all the boundaries and sent the file to fluent. Now when I open my file in fluent only 1 of the 2 interfaces is read in.... Last edited by AnthonyBowers; June 6, 2022 at 12:34. |
Gert-Jan
Rep Power: 27 ![]() |
Go to the fluent forum for more response
ansys, coupling, domains, gas-liquid, membrane |
the coupling between hydrodynamic and morphological module for sediment transport | liuyihui | OpenFOAM Running, Solving & CFD | 1 | September 13, 2022 07:36 |
[swak4Foam] swakExpression not writing to log | alexfells | OpenFOAM Community Contributions | 3 | March 16, 2020 18:19 |
coupling a hydrodynamic model with sediment transport model | Zeinaby | Main CFD Forum | 0 | April 7, 2016 23:21 |
Boundary Condition for region coupling and scalar transport | RugbyGandalf | OpenFOAM | 1 | January 30, 2013 03:51 |
coupling between vorticity transport eq. and stream function eq. (urgent help) | amir2920 | Main CFD Forum | 3 | July 12, 2010 16:01 |
