Having problem in Airfoil Dimple meshing
Old   May 13, 2022, 14:00
Default Having problem in Airfoil Dimple meshing
Azad Kashmir
HassanButt is on a distinguished road
Hello everyone,
I am in final semester of mechanical engineering and have Final year project on Effect of Dimple on airfoil but i am facing problem in dimple meshing. I am not getting structured mesh (picture is attached) so what is the solution of this problem how i can get structured mesh in this region.
HassanButt is offline   Reply With Quote
Old   May 15, 2022, 14:08
Void_CFD-user
Indra is on a distinguished road
Originally Posted by HassanButt View Post
Hello everyone,
There's a bit of division of domain required to get a structured mesh. Also try facemeshing to see if that can put a structured mesh for you. But, i think you'll need to split the body to get structured grid.
Indra is offline   Reply With Quote
Old   May 16, 2022, 04:31
Svetlana Tkachenko
Svetlana is on a distinguished road
Hello everyone,
Did the solutions suggested above work for you?
Svetlana is offline   Reply With Quote
Old   May 16, 2022, 12:41
Default What body region should i spilt?
Azad Kashmir
Thanks for your suggestion. So should i spilt the dimple body region only. And than apply Face meshing? Do you mean that?
[ANSYS Meshing] Meshing problem with airfoil having inward dimple Janet ANSYS Meshing & Geometry 0 August 20, 2019 14:47
High drag for airfoil compared to XFOIL and wind tunnel data Ry10 SU2 15 October 30, 2016 18:27
[ICEM] ICEM 3d meshing problem Eng.Mahmoud abd elsalam ANSYS Meshing & Geometry 0 June 25, 2016 00:16
Problem with restart solution in shape_optimization.py robyTKD SU2 Shape Design 21 May 29, 2013 10:26
[Other] Ansys meshing airfoil and / or compressor blades baw192 ANSYS Meshing & Geometry 8 September 23, 2011 01:43
