April 15, 2022, 17:41 |
Using a C_UDSI in an UDRGM
Karla Jacinto
Rep Power: 6 |
Hi everyone,
I'm learning how to use UDRGM. So, I want to do a two-phase flow with Homogeneous Equilibrium Model (HEM). First I've created a UDF to employ an enthalpy transport equation. For this approach I was using the UDF to read the fluid properties, however, I'm with convergence problems. So, I'm thinking to use UDRGM multispecies for the properties, with lookup tables. And the UDF for the diffusivity. And now I have two questions: I need to read in the UDRGM the C_UDSI (my enthalpy), in order to obtain my properties. But, I don't know how to do it, even if it is possible. My multispecies UDRGM has 2 'fluids', the lçiquid and the vapour phase. I'm confused, how FLUENT gets the yi[] value? Instead of using it, I wanted to compute the flow quality and with that interpolate in my lookup tables to get all the properties that I need. Does this make sense? Thanks to all for the help |
multiphase, udf, udf-fluent, udrgm |
using User Define Real Gas Model (UDRGM) | Amirreza_pro | FLUENT | 0 | November 4, 2020 11:06 |
Enthalpy and Entropy UDRGM | Captain Convergence | Fluent UDF and Scheme Programming | 0 | April 21, 2020 19:23 |
UDRGM and Viscosity UDF | adnunes | Fluent UDF and Scheme Programming | 17 | March 27, 2020 09:40 |
UDRGM multi-phase condensation | Piotr95 | Fluent UDF and Scheme Programming | 0 | December 11, 2019 07:46 |
error with UDRGM | fafa_blues | Fluent UDF and Scheme Programming | 4 | November 19, 2015 06:46 |
