looking for a better way to import data output from fluent to Matlab
Old   March 10, 2022, 07:17
Red face looking for a better way to import data output from fluent to Matlab
guillaume grimard
guillaumeGrimard is on a distinguished road
Hello, for my thesis I have to do some sPOD post processing on my LES simulation in Matlab. Currently I export an ASCII file and read it into Matlab with a text import. The ASCII files are MASSIVE and the Matlab .mat files take up an order of magnitude less space on my hard drive. This tells me that ASCII files don't have a high information / byte ratio. Is there a way to export fluent data that is readable by Matlab that has a lower file size? thanks for the help
guillaumeGrimard is offline   Reply With Quote
Old   November 11, 2022, 14:54
Brad
bw91 is on a distinguished road
Did you ever find a solution to this? I am in an almost identical position.
bw91 is offline   Reply With Quote
Old   November 11, 2022, 15:04
guillaume grimard
Hi, yes I found that it is possible to read out the cas.h5 and .dat.h5 format as HDF5 with Python and Matlab. But it will require a good amount of programming work, also it can be challenging to reconstruct the mesh because it is stored in a clever format & there is not a lot of documententation from ANSYS, but it is possible to reverse engineer. https://github.com/ggrimard/ANSYSfluent is a repo I created in my free time to read the mesh into python.
Old   November 11, 2022, 15:19
Brad
Oh that's awesome. Do you have a different link though? The one provided leads to a "page not found."
Old   November 11, 2022, 15:20
guillaume grimard
It should work now, repo was set to private
Old   November 11, 2022, 15:24
Brad
Yep, all good. Thanks
Old   June 16, 2023, 16:45
Default Spod
Alireza Maleki
alireza94 is on a distinguished road
Hey Guillaume,
I need an assist with SPOD, and I'm wondering whether you could help with that. I'm simulating the flow passing from a rectangular wall-mounted cylinder, I like to do some SPOD on it. Right now, I got my output from OpenFoam in VTK file and I read them in Python. My problem is that the point data are not in structured shape, and they are some points with x and y coordinates and pressure values (in 2d plane) so I need to make a grid mesh and interpolate the data (as far as I know the point information must have regular shape and spacing, or at least the PySPOD developed like this) on this mesh, the point is if I do make a grid mesh to interpolate the data, it creates points inside the cylinder as well and then it tries to interpolate the value inside the cylinder as well that in non-physical!
What should I do at this stage?
alireza94 is offline   Reply With Quote
ascii, csv, matlab, memory, text
Running UDF with Supercomputer roi247 FLUENT 4 October 15, 2015 14:41
Fluent crash on writing data file after thousand iterations Chuck87 FLUENT 0 September 2, 2015 17:17
[OpenFOAM] Annoying issue of automatic "Rescale to Data Range " with paraFoam/paraview 3.12 keepfit ParaView 60 September 18, 2013 04:23
Problem of import fluent data to ilight fieldview seasoul FLUENT 3 September 9, 2008 23:36
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 21:30
