Stress tensor on a surface point on a shaft in cylindrical coordinate system |
March 7, 2022, 16:16 |
I hope you can help me get the stress tensor on two opposite points located on the surface of a shaft in cylindrical coordinate system. The shaft rotates and has a flexor moment, shear force and torque applied at its end. The thing is that I want to use the components of the tensors of these two points in order to calculate the torque in an indirect way. The shaft has a diameter of 25 mm. I would use ANSYS if it's ok. Thanks in advance. I hope you can help me.
cylindrical coordinates, tensors |
[Gmsh] Gmsh and samplesurface | touf | OpenFOAM Meshing & Mesh Conversion | 2 | December 10, 2007 03:27 |
Normal - Helical Surface | m. malik | Main CFD Forum | 3 | February 3, 2006 13:56 |
CFX4.3 -build analysis form | Chie Min | CFX | 5 | July 13, 2001 00:19 |
Star-cd:Refine mesh in cylindrical coordinate system | Moussa Diarra | Main CFD Forum | 0 | May 11, 2000 09:17 |
How to determine a point is inside a tetrahedral? | G.P. Xia | Main CFD Forum | 16 | January 12, 2000 12:15 |
