What's the difference between iso-surface and plane |
February 16, 2022, 23:59 |
Hello everyone!
I'm learning ANSYS Fluent now, and I'm puzzled with the difference between Iso-surface and plane in creating surface in fluent cases. Can you tell me the difference? Thanks |
February 17, 2022, 15:46 |
Erik
Rep Power: 23 |
Iso-surface is a surface where some variable is the same.
If you make that variable for the iso-surface x=0, that would be the YZ plane. but if you made it temperature=100K, it would be all locations that were exactly that temperature, which could be any irregular shaped surface, not just a plane. |
[Gmsh] gmshToFoam generates patches with 0 faces and 0 points | Simurgh | OpenFOAM Meshing & Mesh Conversion | 4 | August 25, 2023 08:58 |
OpenFOAM error | Vinay Kumar V | Main CFD Forum | 0 | February 20, 2020 10:17 |
[Gmsh] Error : Self intersecting surface mesh, computing intersections & Error : Impossible | velan | OpenFOAM Meshing & Mesh Conversion | 3 | October 22, 2015 12:05 |
[Gmsh] Problem with Gmsh | nishant_hull | OpenFOAM Meshing & Mesh Conversion | 23 | August 5, 2015 03:09 |
[Gmsh] boundaries with gmshToFoam | ouafa | OpenFOAM Meshing & Mesh Conversion | 7 | May 21, 2010 13:43 |
