high Temperature shoot up and high mach flow. |
February 16, 2022, 22:32 |
Sanjay
Rep Power: 6 |
Dear Friend,
I was solving the airflow through the Tangle, in order to solve the problem, I choose the flowing fluid as "air" as compressible fluid. I am doing this as a control experiment. Pinlet (Gauge Pressure) :3 atm and Pout(Gauge Pressure) is 1atm. The temperature of the fluid is 300K (constant for inlet and outlet) . Solver: Explicit, ROE and Grad: Node-based and Flow: Second upwind scheme. Initialization: Hybrid Steady-state problem: Gravity: Y-axis :-9.81 Mach flow: Vel/Sqrt(1.4*287*Totat Temp) and Courant Number:1 and I am not sure, why I am getting such a high temperature and Impossible Mach number through the T-channel. This result in the CFD post doesn't make any sense. I am not sure where I am making mistakes in defining the BC or meshing issue., solver, or anything else. Do I need to put any operating pressure, if I am just simulating for the flow at atmospheric conditions? any suggestion will be helpful. Error shown by TUI for every iteration: Solver: " time step reduced in 707 cells due to excessive temperature change temperature limited to 1.000000e+00 in 729 cells on zone 3 temperature limited to 5.000000e+03 in 961 cells on zone 3 200 1.8851e+00 5.7939e-01 8.1209e-01 7.1154e-01 8.3318e-01 0:00:00 0 " For Picture please look into : https://forum.ansys.com/discussion/3...ch-flow#latest |
February 19, 2022, 07:35 |
Void_CFD-user
Rep Power: 4 |
Looks like your problem has been solved in ANSYS forum.
But here's a tip, you can control the relaxation for your temperature as well with positivity rate limit under solution controls>limits. It's only available for density-based solver. But as mentioned in the forum, Pressure based will work just fine for transonic and low supersonic flows. |
boundary condition, compressible flow problem, fluent |
