iteration reset
Old   February 7, 2022, 10:46
Default iteration reset
widad
widad is on a distinguished road
I used Fluent for Flow simulation, but i have a problem with incrementation of iterations wich is blocked in one number as you can see below :
iter continuity x-velocity y-velocity z-velocity energy k
!16777216 solution is converged
How can i reset the iteration
widad is offline   Reply With Quote
Old   February 7, 2022, 22:31
Ash Kotwal
Ash Kot is on a distinguished road
Press Enter in TUI box
type solve/
Press Enter
type monitors/
Press Enter
type residual/
Press Enter again
type reset/
It'll ask question
Type yes or Y
Done, the iterations are reset
Ash Kot is offline   Reply With Quote
Old   February 7, 2022, 22:33
Ash Kotwal
You can also do this:
In Ansys Fluent V19.2 you can also reset the iteration count by clicking 'solution' tab, and under Reports click 'residuals'. In here change the 'iterations to store' to '0' and 'plot'. This appears to reset the iteration monitors.
Old   February 15, 2022, 08:29
Default Floating point error
widad
I have a simulation with UDFs , so i compiled ( build and load ), but when i run the calculation i have a message error that are a floating point and divergence. But when i run in batch it work normally
Slow calculation time on CFD server killian153 Hardware 4 July 27, 2021 08:28
to reset iteration number in FLUENT Mohan R FLUENT 5 July 25, 2019 04:57
Free surface issues with interDyMFoam for hydroturbine oumnion OpenFOAM Running, Solving & CFD 0 October 6, 2017 15:05
Hardware-Configuration for Fluent HPC-Pack (8x) JohHaas Hardware 9 March 3, 2015 14:25
Parallel runs slower with MTU=9000 than MTU=1500 Javier Larrondo FLUENT 0 October 28, 2007 23:30
