converting 2D axissymetric solution to 3D cartesian data
Old   January 24, 2022, 10:54
Default converting 2D axissymetric solution to 3D cartesian data
Alex
AlexTl is on a distinguished road
Thank you for taking your time to check out my question. I'm having troubles figuring out how I can export 3D data on a cartesian mesh from a 2D axissymetric solution ran in Fluent. Using CFD-post I cannot figure it out. The idea is to export a csv file containing some flow parameters on a cartesian mesh where the same cell size is used as the 2D solution with an extra Z component which has the same cellwidth dz(=dy=dx).
For example the 2D domain is 700x100 cells which I am able to export without a problem. However I want a rectangular 3D domain that is completely defined so there are parts of the cilinder that are obsolete. E.g Figure 1: the green line indicating the 2D solution has a height of 100 cells, making the required 3D mesh height and width sqrt(2)*100 = 141 cells (the red lines).
So ideally I want to export 701*142*142 nodes and their corresponding flow parameters. Tried multiple things thinking that I would at least get the solution on the complete domain using this and then interpolate myself but I get the same output file when I choose Volume 1 or Plane 1 (Figure 2)
At this point I don't even know if it's possible to achieve this using Ansys or Post, that I have to do it myself with python/matlab/.. Or a combination of both.
Any help or guidance is highly appreciated.
AlexTl is offline   Reply With Quote
Importing solution final data DelRivo FLUENT 6 May 25, 2022 10:56
UDF for Automatic Solution Initialization for previous case data file gartz89 Fluent UDF and Scheme Programming 6 March 30, 2020 08:38
studying a valve case mina.basta OpenFOAM 33 August 30, 2013 05:46
[Commercial meshers] fluentMeshToFoam multidomain mesh conversion problem Attesz OpenFOAM Meshing & Mesh Conversion 12 May 2, 2013 11:52
How to update polyPatchbs localPoints liu OpenFOAM Running, Solving & CFD 6 December 30, 2005 18:27
