Ansys Aqwa, how to set only a vertical movement?
Old   January 24, 2022, 01:26
Default Ansys Aqwa, how to set only a vertical movement?
sid mez
burning08 is on a distinguished road
I started recently using Ansys Aqwa (Hydrodynamic diffraction), my goal is to realize a numerical simulation about a buoy which is linked (very small gap) to a fixed tower. The results I get show that the Buoy tilts up and down in the model if it were a ship. However, in reality the buoy only act with the heave of the wave in a completely vertical movement. Also, it seems that the structure interaction between the buoy and fixed tower, physically absent.
What is the possible config to give the buoy only a vertical movement ?
Best regards.
burning08 is offline   Reply With Quote
ansys aqwa, buoy, hydrodynamic diffraction, inertial moments
Hydrodynamic Analysis of a submersible body using Ansys Aqwa irfan CFD Freelancers 20 April 7, 2023 15:01
Ansys AQWA Multibody RAO calculation nielssievd ANSYS 2 June 9, 2021 09:23
[Other] movingConeTopoFvMesh for vertical movement jiahui_93 OpenFOAM Meshing & Mesh Conversion 0 May 7, 2018 06:35
Pro/E to ANSYS Parameterization Guide Trues ANSYS 4 April 18, 2018 06:52
2-way FSI in Ansys CFX 15 LucasGasparino CFX 3 August 6, 2015 04:17
