marcel schmidt
Rep Power: 0 ![]() |
I am a student creating a mesh for the main rotor work chamber of a screw compressor. I am using ICEM because my Task is to make a structured Hex Mesh. First I constructed the Chamber and help Survaces to orientate the O-Grid with Inventor, than i exported it as a .STP After this i open ICEM, go to Settings-->Model/units and choose Millimeters as the Unit and set my Tolerances to 0.0000001. Than I got to File-->Import Model so the constructed Chamber appears. After importing the model I create the parts and go to pre-mesh-params. I vary the pre-mesh-params until the mesh looks good. https://ibb.co/5GbdGDx Then I go to "find worst elements" and check for volume. in the pre mesh all volumes are positive. after I convert the mesh to an unstructured mesh and go to "check mesh", there are many cells with non-positive volume. https://ibb.co/J51LvPv I have already read some things, but have not found a solution ![]() How can i fix the problem ? thanks for your help ![]() |
icem, mesh, negative volume |
[ANSYS Meshing] ICEM Meshing problem | drvincentip | ANSYS Meshing & Geometry | 1 | May 2, 2013 17:31 |
[ICEM] Problem with ICEM Script Meshing | asal | ANSYS Meshing & Geometry | 2 | March 23, 2013 19:11 |
[ICEM] ICEM meshing problem | xyq102296 | ANSYS Meshing & Geometry | 6 | October 28, 2010 10:09 |
[ICEM] Meshing problem from ICEM CFD to Fluent | cfdonlinederafa | ANSYS Meshing & Geometry | 2 | September 21, 2010 16:16 |
ICEM meshing problem | Forrest | CFX | 4 | May 25, 2005 18:37 |
