November 24, 2021, 23:22 |
Cyclone Efficiency
Rep Power: 5 |
Hi i am a masters student, i am new to this fluent ansys simulation.
I did a cyclone simulation with fluent ansys for my thesis research. I tried to simulate the cyclone from wang et al 2006 journal, but when i increase the inlet speed, the efficiency decreases. I've tried increasing the iteration value, but I haven't seen any changes yet I tried this simulation in steady state and using the rsm model, using DPM and rosin-rammler, boundary condition that i used is velocity inlet, outflow and wall. First order scheme for momentum equation and the turbulent kinetic energy k and the turbulent dissipation rate ε and the Reynolds stress equations were employed for spatial discretisation. The SIMPLEC algorithm was used for pressure-velocity coupling and the standard scheme for pressure discretisation. I hope to get some suggestions thanks in advance for the reply |
November 25, 2021, 15:39 |
Guven Nergiz
Rep Power: 6 |
I have 2 questions depends on your case;
1) While you saying inlet speed, do you mean there is a inlet velocity boundary condition in your case? If you say so, shouldnt be a vacuum boundary condition intead of velocity inlet in cyclones? 2) Wouldn't it be more difficult for the particles to escape the flow due to centripetal forces from high velocities? Isn't it normal for efficiency to drop for this reason? |
November 25, 2021, 22:39 |
Rep Power: 5 |
Yes velocity inlet in the boundary condition
But in the journal that i was tried to simulate, the efficiency increases |
November 25, 2021, 22:41 |
Rep Power: 5 |
but i was wondering, what do you mean about vacuum boundary condition, would you like to explain for me about this?
thank you for your reply |
November 26, 2021, 08:50 |
Guven Nergiz
Rep Power: 6 |
I wanted to mean suction while saying vacuum. On this kind of seperation systems, fluid need to be suction from dusty area. Examples are below. Thats why there should be a mass flow outlet in the cyclones actually, not mass flow inlet.
https://www.youtube.com/watch?v=pEVpF404Hu8 Sample.jpg |
November 29, 2021, 23:01 |
Rep Power: 5 |
Cyclone separation efficiency using CFX | Benfa | CFX | 20 | April 9, 2019 14:10 |
Separation efficiency in an straight through cyclone with water | Cloudseeker | Main CFD Forum | 2 | February 12, 2016 05:17 |
Cyclone separation efficiency & Particle Trajectories | Mukhtiar Ali | FLUENT | 0 | December 26, 2013 01:19 |
How can I find collection efficiency of cyclone by fluent? | YuTsuYu | FLUENT | 1 | July 2, 2013 16:46 |
Cyclone efficiency in DPM | arjun3020 | FLUENT | 0 | February 28, 2012 00:31 |
