Fluent: Proper Solver for Pressure ratio in high pressure turbine
Old   August 20, 2021, 01:09
Default Fluent: Proper Solver for Pressure ratio in high pressure turbine
LotusRose is on a distinguished road
I have to calculate pressure ratio of high pressure turbine. Turbine is a part of jet engine.
I have doubts if it is possible to count that in fluent because I'm not sure if Fluent can solve case when the stream should move rotor blades.
I have data like:
- pressure before turbine
- mass flow rate
- blades rotation speed
In my case I set:
- pressure-based, Steady
- K-epsilon, Realizable, Enchanted Wall Function
- moving frame with rotation-Axis Direction (1,0,0) and Rotation speed 870 [rad/s]
- BCs: pressure-inlet, pressure-outlet, rotation vector of walls (1,0,0), periodicity
- Scheme: Coupled, Gradient: G-G Node Based, Pressure: Standard, Momentum & Energy: Second Order Upwind, Turbulence Kinetic Energy & Turbulence
LotusRose is offline   Reply With Quote
High pressure nitrogen discharge simulation in Fluent jzapatau FLUENT 0 October 2, 2016 18:54
static vs. total pressure auf dem feld FLUENT 17 February 26, 2016 14:04
high aspect ratio mesh problem appears in fluent hesham FLUENT 0 January 24, 2016 16:41
replacing of shock tube high pressure part with a boundary condition for low pressure immortality Main CFD Forum 0 May 2, 2013 14:30
what boundary condition is proper for simulation of shock-tube low pressure part? immortality OpenFOAM Running, Solving & CFD 0 May 2, 2013 14:22
