July 24, 2021, 02:41 |
Unique problem with 3D wing case in FLUENT
Md Anwar Parvez
Rep Power: 6 |
I am doing simulations on a 3d wing with every option verified and i am doing it steady state. I am doing different AOA. AOA 0,2,6,10,14 specifically. Problem is that i didnt change anything in the mesh or the options and first 3 AOA (0,2,6) were fine and ran for the whole time without any issue. But with 10 and 14 degree, fluent starts to give the warnings like "absolute pressure limited to", "temperature limited to", "time step reduced to excessive temp change" and starts to give wrong values. I dont know whats happening here as first 3 AOA were fine with correct results (verified with experimental). Please give me your opinion. Thank you |
angle of attack, fluent |
how to run fluent from matlab without using aas toolbox? | artemis96 | ANSYS | 7 | May 23, 2022 12:16 |
looking for a smart interface matlab fluent | chary | FLUENT | 24 | June 18, 2021 09:07 |
Dual-Element Front Wing Case Using SST K-OMEGA TURBULENCE MODEL | Jesus.M | OpenFOAM Running, Solving & CFD | 1 | December 14, 2020 13:48 |
How to set up a 2D Taylor-Couette case in FLUENT? | Maggakahn | FLUENT | 5 | March 5, 2020 07:18 |
A problem in a Fluent case after I created the interface | ama294 | Fluent UDF and Scheme Programming | 0 | January 29, 2018 23:32 |
