June 14, 2021, 04:04 |
Airfoil - Inverse Design/ Shape Optimization
Good day,
I have a question about the following task: Based on a given NACA profile and the pressure distribution evident from an initial simulation, I would like to generate a new profile with the same/ a very similar pressure distribution after adjusting the flow conditions. Now I need a hint how to realize the project in ANSYS. I have already parameterized the pressure side of the single profile in the DesignXplorer (x,y-coordinates). However, I currently do not know how I can integrate the static pressures along the PS as target values. Is for the above mentioned problem another methodology possibly more advantageous (e.g. Adjoint Solver, BladeModeler)? Especially with respect to the later following, intended geomteric study and airfoil generation in a cascade flow. I would be pleased about your assistance. With kind regards Opal |
March 7, 2022, 16:20 |
jose daniel
Rep Power: 6 |
You can find the optimal airfoil shape (minimizing the drag) but fulfilling a target lift coefficient on this website: https://aeroptimal.com/airfoil . The methodology is under review in journals. The CFD method employs OpenFOAM.
March 8, 2022, 04:21 |
#3 | |
Void_CFD-user
Rep Power: 4 |
If you run a prameter study in workbench along with designexplorer, it'll give you the performance of foil at each input parameter and you can get a response surface that'll tell you how performance changes with you input parameter. Both ways can be used, adjoint although gives you some unique shapes. |
Continuous adjoint converge issue in transonic airfoil shape design | zloty001 | SU2 Shape Design | 0 | December 15, 2019 09:13 |
Inverse Design Optimization | khavart | SU2 Shape Design | 0 | June 20, 2019 03:37 |
FFD 2D for inverse shape design using target CP | ericclaro | SU2 Shape Design | 1 | May 30, 2019 18:53 |
Inverse design Cp file | yugang881 | SU2 | 2 | December 9, 2017 04:03 |
Inverse design and Optimization of Aircraft Wings | Simon Nava | Main CFD Forum | 8 | May 22, 2007 14:55 |
