April 22, 2021, 22:28 |
k-omega SST: y+>11.25
Rep Power: 5 |
In the k-omega SST model I know that at values of y+<11.25 The model k-omega is used. And this model do not need wall functions. If the y+>11.25, the k-epsilon is used. Normally, when we select the k-epsilon model (not k-omega SST) we can select the wall function. While in k-omega SST, it is not possible. My question is: Does the k-omega SST apply a wall function if the y+>11.25 ( when the k-epsilon is used ) ? |
overshooting of Omega in SST komega using simpleFoam | cm_jubayer | OpenFOAM | 2 | June 7, 2020 13:52 |
Weird result by k omega SST | bingo641 | OpenFOAM | 3 | May 28, 2018 00:05 |
Setting change from k omega to k omega SST | bingo641 | OpenFOAM Programming & Development | 0 | May 22, 2018 06:15 |
how to calculate the omega at inlet boundary in k omega sst | Scabbard | OpenFOAM Running, Solving & CFD | 2 | September 30, 2014 14:06 |
Boundary Conditions for k omega SST | dancfd | OpenFOAM Pre-Processing | 0 | June 10, 2011 00:25 |
