skewed elements due to semi circular geometry
Old   March 15, 2021, 15:43
Default skewed elements due to semi circular geometry
Saurabh
saurabh1011 is on a distinguished road
So I am meshing this one part of the larger assembly (Part geometry shown below)
The surface on the front side has a semi-circle in it. I am using a semi-circle part of the front side as an inlet for fluid flow. After meshing this part, I got this mesh geometry.
You can notice that the edges of mesh elements inside the semi-circle are not tangent with the edges of elements outside the semi-circle.
Then I made some changes in assembly without making any changes in this part. But when I meshed this part again, I got this new mesh geometry (given below) which is different from the first one even though both part geometries are the same and I am using the same mesh settings for both.
here you can notice that edges of mesh elements inside semi-circle are in tangent with edges of elements outside of the semi-circle
I think that these tangential edges are creating a small region of very skewed elements outside the semi-circle.
I want to remove this region of skewed elements and make the mesh the same as the first one. I don't know why but I can not recreate the first mesh even though I am using the same mesh settings.
saurabh1011 is offline   Reply With Quote
Using PengRobinsonGas EoS with sprayFoam Jabo OpenFOAM Running, Solving & CFD 36 July 16, 2024 04:52
Can highly skewed elements create problem?? Sanjay Jain FLUENT 1 April 8, 2008 16:57
help: the volume mesh has highly skewed elements xiaofish FLUENT 3 September 18, 2007 10:51
vitual _ real deneb FLUENT 3 January 22, 2007 05:31
Highly skewed elements Hengky FLUENT 2 August 11, 2005 13:17
