March 12, 2021, 22:05 |
Mesh Errors for an Turbofan Engine
I have been working on a project where i will be simulating flow over a nacelle (aircraft turbofan). I do not require simulating the exhaust flow as that is not the area of study, only the inlet region is required. (recreating a this research for my own project with my own engine nacelle geometry) The Research Paper that i will be reproducing: https://citeseerx.ist.psu.edu/viewdo...=rep1&type=pdf I am currently stuck on the meshing stage of the CFD as i now continue to get an error. The Error says "Patch-conforming tetrahedron mesh failed because of an edge intersection in the boundary mesh." I am new to Ansys CFD and would appreciate if anyone can help me solve this error. Thanks |
ansys, cfd, fluent, mesh, nacelle |
[snappyHexMesh] non uniform mesh near the stl object | vava10 | OpenFOAM Meshing & Mesh Conversion | 0 | January 31, 2021 15:41 |
decomposePar problem: Cell 0contains face labels out of range | vaina74 | OpenFOAM Pre-Processing | 37 | July 20, 2020 06:38 |
[mesh manipulation] Importing Multiple Meshes | thomasnwalshiii | OpenFOAM Meshing & Mesh Conversion | 18 | December 19, 2015 19:57 |
dynamic Mesh is faster than MRF???? | sharonyue | OpenFOAM Running, Solving & CFD | 14 | August 26, 2013 08:47 |
Convergence moving mesh | lr103476 | OpenFOAM Running, Solving & CFD | 30 | November 19, 2007 15:09 |
