February 24, 2021, 05:20 |
Kvs calculation - Pressure drop
Hello everyone,
I'm trying to verify my Kvs for a regulation valve with Ansys. As you know the Kvs value has to be calculated with water and 1 bar differential pressure My question is this: I was thinking using Inlet Pressure and Outlet Pressure as boundary conditions, with: _ Inlet Pressure: Gauge total pressure 10 bars _ Outlet Pressure: Gauge total pressure 9 bars Is it correct to process this way ? I am still a bit confused with all the pressure in Ansys, as many of us. Thank you |
fluent - udf, kvs, pressure drop |
Pressure fields in FOAM, p field, total pressure, etc. | Tobi | OpenFOAM Post-Processing | 9 | March 25, 2022 02:33 |
pressure drop calculation | ayad | FLUENT | 7 | October 21, 2014 09:32 |
Mass flow rate prediction of Purge control valve using set pressure drop | enr_venkat | CFX | 11 | February 27, 2014 12:30 |
Pressure drop calculation and comparison to analytic solutions | n0name | STAR-CCM+ | 2 | August 16, 2012 04:36 |
pressure drop calculation | ahsan | FLUENT | 0 | September 6, 2009 06:38 |
