Rep Power: 0 ![]() |
Hi I have a project that requires two separate fluid domains set up to simulate a tidal turbine. These will both then be boolean away from the main domain and then set up to porous media. I am struggling to have two separate solid bodies in ansys without them combining, once they contact each other they combine and become 1 body. There might be an easier why like separating a solid body into two sections for fluid but they both need to be “add material” operation for the Boolean to work, can’t be “add frozen”. Thanks in advance!
ansys 2020, blade element momentum, designmodeller, fluent, tidal turbine |
Problem with torque output from a turbine simulation. | pa-dundas | FLUENT | 5 | July 17, 2022 05:27 |
6dof for rotation of turbine: unable to fix the center | Havinh | Fluent UDF and Scheme Programming | 0 | August 5, 2015 05:35 |
[TGrid] Water Turbine meshed in TurboGrid: Geometry and Topology issues | ama294 | ANSYS Meshing & Geometry | 12 | September 29, 2014 13:23 |
Air Flow Analysis around a Wind Turbine | NightHawkRaven | FLUENT | 4 | August 12, 2014 17:18 |
Boundary condition setting regarding turbine simulation using CFX | Lacerlacer | CFX | 11 | March 12, 2012 09:32 |
