How can I use this file for centrifugal compressor simulation?
Old   February 9, 2021, 13:28
Default How can I use this file for centrifugal compressor simulation?
Ataberk
berkozaydin is on a distinguished road
Hello everyone,
I have two simple questions. I have a .tinXML file for one blade of the centrifugal compressor. I looked at the many different programs such as ICEM, TurboGrid, Cfturbo. However, I could not understand how I can use this file? You can find the file description below (1).
Also, I have surface geometry (not body). How can I use this geometry for turbomachinery simulation? It cannot be converted to a solid body. Therefore, my mesh cannot be implemented on the CFX. If there is any recommendation for these questions, I will very appreciate. Thank you.
I add the first lines below (1):
<?xml version="1.0" encoding="UTF-8" standalone="yes"?>
<CFturboFile Version="10.4">
<ProjectType>Compressor</ProjectType>
<LengthUnit>[mm] Millimeters</LengthUnit>
<Tritolerance Type="Float">1E-6</Tritolerance>
<BuildTopoTolerance Type="Float">5E-5</BuildTopoTolerance>
<Version>10.4.7.30</Version>
<Component Name="_IMPELLER_1_">
<StepFile>compyenideneme_Co1.stp</StepFile>
<ComponentType>Radial_Impeller</ComponentType>
<MeshMethod>Delaunay</MeshMethod>
<GlobalParams>
<Topology>Full</Topology>
<SegmentCount Type="Integer">9</SegmentCount>
<Scale Type="Float">1</Scale>
<MinTetSize Type="Float">0.25</MinTetSize>
<MaxTetSize Type="Float">2</MaxTetSize>
<EdgeCriterion Type="Float">0.15</EdgeCriterion>
<PriLayers Type="Integer">7</PriLayers>
<PriRatio Type="Float">1.2</PriRatio>
<PriLaw>Linear</PriLaw>
</GlobalParams>
<LocalParams>
<Part Name="Hub">
<MaxDeviation Type="Float">1.4395421</MaxDeviation>
<PriHeight Type="Float">0.011160714</PriHeight>
<PriLimit Type="Float">0.0625</PriLimit>
<PriActiv Type="Boolean">1</PriActiv>
</Part>
<Part Name="Shroud">
</Part>
<Part Name="Blade">
<MaxTetSize Type="Float">1</MaxTetSize>
<PriLimit Type="Float">0.125</PriLimit>
</Part>
berkozaydin is offline   Reply With Quote
Old   February 9, 2021, 17:49
jmenendez is on a distinguished road
It seems a CFTurbo file. CFTurbo has interface with ANSYS Workbench, see: https://cfturbo.com/es/software/inte...nsys-workbench
Try taking a look at Bladegen, a highly automated turbomachinery design program within ANSYS.
jmenendez is offline   Reply With Quote
centrifugal compressor, cfturbo, cfx, turbogrid, vista
how to calculate mass flow rate on patches and summation of that during the run? immortality OpenFOAM Post-Processing 104 February 16, 2021 09:46
[foam-extend.org] problem when installing foam-extend-1.6 Thomas pan OpenFOAM Installation 7 September 9, 2015 22:53
[swak4Foam] Problem installing swak_2.x for OpenFoam-2.4.0 towanda OpenFOAM Community Contributions 6 September 5, 2015 22:03
"parabolicVelocity" in OpenFoam 2.1.0 ? sawyer86 OpenFOAM Running, Solving & CFD 21 February 7, 2012 12:44
ParaView Compilation jakaranda OpenFOAM Installation 3 October 27, 2008 12:46
