Ansys fluent hyperthreading
Old   January 11, 2021, 12:55
Smile Ansys fluent hyperthreading
Spiros Kouzoupis
Spiros Kouzoupis is on a distinguished road
I want to know, i have an Intel i7 8700k 6 cores 12 threads, now i use ht on, my cpu works 100% when i run my simulation. In UI in ansys fluent i put 12 cores (meaning 12 so i can tell fluent that there are 12 logical cores) and 1 gpu. Would it run faster if i turned off ht and so put 6 cores and 1 gpu? Also would help to upgrade to i9 9900k?
Spiros Kouzoupis is offline   Reply With Quote
Old   January 20, 2021, 11:16
Erik
evcelica is on a distinguished road
Why not try turning off HT and see for yourself?
Both those CPUs only have 2 memory channels, so i suspect you are memory bandwidth limited, not CPU limited, and there would not be too much difference between the CPUs, as it won't scale well past a few cores anyways. I would pick up a CPU with at least 4 memory channels, which would be roughly 2x the speed of your machine. CFD is usually memory bandwidth limited.
evcelica is offline   Reply With Quote
Old   January 20, 2021, 13:11
Spiros Kouzoupis
I switched off ht, but because other problems i cant compare the result in time. Every simulation cost me 1 month, if i want to compare i have to run the same simulation 2 times, so 2 months at least. Also ansys sometimes crashes by it self so its not possible to compare. Im Just asking by techincal point of view.
Old   January 21, 2021, 13:57
Default Comment mode
Eng.Meshal is on a distinguished road
for 2D pipe flow, we useTb (bulk temperature) formula,
lengthInt(Velocity u*Y*Temperature)@radial/ lengthInt(Velocity u*Y)@radial
How to put the formula in comment mode to find results?
Please help
Eng.Meshal is offline   Reply With Quote
Old   February 10, 2021, 06:13
flotus1's Avatar
Alex
flotus1 has a spectacular aura aboutflotus1 has a spectacular aura about
Step 1 is usually to get a test case that can be run in minutes, but is still representative of your actual application.
But with a run time of 1 month you can probably skip that entirely. You need something way more substantial than the small difference between SMT off/on. What that might be, depends on why your simulation takes this much time.
Maybe the cell count is so high that the simulation does not fit in memory. In that case, you would need more RAM. And better CPUs than a mainstream 6-core processor.
Maybe it's because your simulation runs a very high number of iterations/time steps. In which case there is not much you can do about it from a hardware perspective. Careful evaluation of the simulation parameters is the better approach here.
Or maybe your simulation does a lot of file-I/O, some of which might be unnecessary. Here a faster storage solution might help.
Tell us more about the simulations you are trying to run.
flotus1 is offline   Reply With Quote
fluent, hyperthreading
GPU acceleration in Ansys Fluent flotus1 Hardware 63 May 12, 2023 03:48
Using ANSYS Fluent 18.0 on workstations with multiple network cards and PBS Pro cheezum Hardware 0 February 28, 2017 11:23
How to combine ANSYS Fluent and Structural analysis? diwakar ANSYS 2 June 18, 2015 13:07
few quesions on ANSYS ICEMCFD and FLUENT Prakash.Paudel ANSYS 0 August 12, 2010 13:07
Fluent & Ansys FSI architecture help DillonS FLUENT 1 April 7, 2010 17:00
