December 18, 2020, 23:56 |
Discontinuity in the post-processing results
Naveen
Rep Power: 8 |
I'm simulating the savonius turbine 2D model. In the post-processing, I observed that the contours are not continuous. I simulated used sliding mesh method. The mesh and post-processing are results are attached. The areas are in the interface are perfectly matching. I used an auto-create mesh interface feature. Please suggest a suitable solution.
October 10, 2022, 04:31 |
Discontinuous velocity contour
#2 | |
Mostafa Mahmood Hamed
October 11, 2022, 10:49 |
Erik
Rep Power: 23 |
I have never done something like this before, so I'm just guessing here. It may have something to do with the reference frames? Perhaps you need to show two different contours in the two different reference frame geometries in order to make them consistent. Set the min and max scale manually to be the same on each of them, then show them both at once.
Problem: Cannot get Results to work in post processing | mattsarg55 | Visualization & Post-Processing | 0 | August 5, 2019 11:50 |
Post processing journal - like .cst in CFD Post | Jiricbeng | FLUENT | 0 | April 24, 2019 09:08 |
Run time post processing vs Post run post processing | pruthvi1991 | OpenFOAM Post-Processing | 1 | February 19, 2015 15:15 |
Post processing in FLUENT | Nathan_Donaldson | FLUENT | 4 | April 12, 2012 13:43 |
post processing field average in cht | moritzhoefert | OpenFOAM Pre-Processing | 0 | January 11, 2012 11:41 |
