Gas liquid Absorption/ mass transfer
Old   December 14, 2020, 01:43
Default Gas liquid Absorption/ mass transfer
Evan Marquez
Evan7 is on a distinguished road
I want to simulate a riser system, a pressurized gas( Co2/methane) being injected into a pressurized vessel full of liquid (internal olefin) The pressures are the same. The gas bubbles go through the liquid at a inlet flow rate and then exits the system ( atmospheric pressure). As the gas bubbles go through, some will dissolve into the liquid. I’m trying to find the rate at which the gas dissolves into the liquid at different pressures, bubble size, and inlet gas velocity.
Evan7 is offline   Reply With Quote
Unrealistic simulation of mass transfer from liquid to gas using reactingTwoPhaseEule yaoyn OpenFOAM 1 May 15, 2019 19:37
Domain Reference Pressure and mass flow inlet boundary AdidaKK CFX 75 August 20, 2018 06:37
Ansys CFX problem: unexpected very high temperatures in premix laminar combustion faizan_habib7 CFX 4 February 1, 2016 18:00
Water subcooled boiling Attesz CFX 7 January 5, 2013 04:32
Constant velocity of the material Sas CFX 15 July 13, 2010 09:56
