Using experimental data (temperature) in Ansys to find conductivity
Old   December 1, 2020, 07:05
Default Using experimental data (temperature) in Ansys to find conductivity
Jannis
JannisSif is on a distinguished road
I am trying to simulate the following case:
A soil domain having two different layers of soil (thus 2 different thermal conductivities), which is being heated up on its top surface for a period of 3 years (transient simulation). However, the conductivity values are unknown.
I have experimental measurements of temperature in 4 locations in the soil (2 in each layer with different conductivity), which I want to use in order to find the two different conducutivities using the "optimization" component.
I think my case is quite similar to the one discussed in this forum https://forum.ansys.com/discussion/7...t-conductivity.
However, I do not understand how can I calculate in CFD-Post the temperature at a point in a specific timestep and then export it in order to use it in in the optimization procedure.
Thank you in advance!
Best regards,
Jannis
JannisSif is offline   Reply With Quote
Old   March 6, 2021, 15:48
Jack
rogbrito is an unknown quantity at this point
Boa tarde. Eu consigo estimar o fluxo de calor com as temperaturas experimentais usando outro pacote computacional. Sobre a condutividade, acredito que seja possivel.
rogbrito is offline   Reply With Quote
cfd-post, conductivity, optimization, transient
Is all experimental data needed for hyperelastic modelling in ANSYS? PranjalNewton Structural Mechanics 8 September 11, 2020 11:10
How to retrieve Temperature Data matrix from CFD post? Shaheer FLUENT 0 January 25, 2017 09:17
Simple piston movement in cylinder- fluid models arun1994 CFX 4 July 8, 2016 03:54
Ansys Structural Environmental Temperature zytra Structural Mechanics 0 October 31, 2014 15:32
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 07:27
