ICEM blocking associations
Old   November 24, 2020, 11:44
Default ICEM blocking associations
James
jmetcalfe is on a distinguished road
I am starting work on blocking of a turbine blade, unstructured tetrahedral, in a cone shaped domain. I have set up the geometry and initialised the blocking.
I was wondering what is the next best step: should I split the initial square shaped block since it will be easier to build up associations or should I associate the blocking to the cone first and then split the geometry around the blade? I have attached a photo of the geometry in question and was wondering if anyone had any good guides (video/article form) on the matter.
Kind regards
jmetcalfe is offline   Reply With Quote
[ICEM] Correct blocking and Ogrid in ICEM salumi ANSYS Meshing & Geometry 3 November 8, 2016 11:10
[ICEM] Extract Blocking associations from existing Mesh McCharles ANSYS Meshing & Geometry 0 May 24, 2016 06:25
[ICEM] Need help with ICEM blocking associations badboyz31 ANSYS Meshing & Geometry 2 March 8, 2014 12:36
[ICEM] Structured grid without blocking in ICEM BahaZero ANSYS Meshing & Geometry 19 March 5, 2013 12:36
[ICEM] Using Blocking with ICEM (infinite blocking lines appeared) Touré ANSYS Meshing & Geometry 2 August 5, 2012 18:27
