How to add three layer of different coating in ansys geometry |
November 13, 2020, 16:31 |
AJMIT KUMAR
Rep Power: 6 |
I have a turbine blade geometry & i want to add thermal barrier coating
(3 coat layer with different thickness). I tried many softwares & ansys geometry also. After adding three coat layer with surface offset method (surface with face) & added thickness in outward direction. when i add only one layer then it's fine but when i add three layer & save it in iges file then again import in ansys geometry, automatically so many (more than original one) surface & body created in ansys. Kindly tell me the correct procedure. |
November 16, 2020, 04:14 |
AJMIT KUMAR
Rep Power: 6 |
Problem Solved, when I saved in parasolid format (text or binary) instead of iges. If we create solid body from surface body, i.e, coating then it must be saved in parasolid format to retain the file otherwise in iges format automatically so many redundant surface & bodies will generate
[mesh manipulation] createpatch not working when using layer addition in snappyHexMesh | Dikkeunit | OpenFOAM Meshing & Mesh Conversion | 0 | February 3, 2020 10:46 |
[snappyHexMesh] Problem airfoil snappyhexmesh add layer | bye bye my blue | OpenFOAM Meshing & Mesh Conversion | 1 | May 5, 2017 06:56 |
[snappyHexMesh] sHM layer process keeps getting killed | MBttR | OpenFOAM Meshing & Mesh Conversion | 4 | August 15, 2016 04:21 |
[snappyHexMesh] Boundary layer generation problems | ivan_cozza | OpenFOAM Meshing & Mesh Conversion | 0 | October 6, 2010 14:47 |
Problem importing GAMBIT mesh to Ansys geometry | David G. | CFX | 0 | June 19, 2005 07:01 |
