System coupling timestep
Like Tree1Likes
Old   November 8, 2020, 13:17
Default System coupling timestep
Luigi* is on a distinguished road
I have to make a fluid-structure analysis with system coupling. During the analysis I have to change the timestep, but I know that the timestep must be fixed during the run in system coupling.
So I made 2 analysis in succession, when I have to change the timestep, the analysis is stopped and then restarted with a new timestep.
To avoid the stopping and the restarting, is there a way to define the change in the timestep before the analysis begins?
Thanks
Luigi* is offline   Reply With Quote
Old   November 10, 2020, 06:26
Thanks, I have another question. In my analysis I introduce a discrete phase (dpm), and before the restarting I check if the trajectories of particles are ok, then I restart the analysis with the change in timestep.
At the end it seems that the system recalculates also the trajectories related to the first part of the analysis, but now based on the new flow field.
Do you have any advice on how to manage the dpm solutions when I restart the analysis?
ansys mechanical, fluent, fluid-structure, system coupling, timesteps
CFX System Coupling - How to rotate an Outlet Boundary Condition zjuv9021 CFX 1 April 7, 2019 00:36
Time dependent piezoelectric actuation voltage with system coupling for 2 way fsi Francis Hauris ANSYS 0 April 1, 2018 23:23
Remeshing_ ANSYS 14.0_ System Coupling acdesa ANSYS 4 November 2, 2016 10:12
System coupling problem Sony FLUENT 0 September 17, 2013 21:51
Restarting batch job of system coupling in ANSYS14 bbhv ANSYS 0 June 25, 2012 09:30
