Lorenzo
Rep Power: 7 ![]() |
Hi everyone,
I am trying to simulate a manifold containing pressurized oil. The latter enters the manifold at a specific flow rate, unknown pressure; there, the bc is mass-flow-inlet, in which I specify the flow rate and the direction normal to the boundary. After that, the oil reaches multiple oil jets. I know the mass flow rate in each oil jet, thus I specify the bc outflow, in which I set the percentage of total flow rate exiting each jet. The material is specified with a density of 950 kg/m2 and a viscosity of 0.0045 kg/m-s. The models employed is the standard k-eps method. With this method, the model is not able to converge. If I try a laminar method, the pressure distribution reaches a stable situation, but in many oil jets I measure a negative pressure (lower than the inlet pressure). Can anybody help me solve this issue and get a stable and meaningful pressure distribution? Cheers Lorenzo |
cfd, fluent, helicopter, oil |
Calculating pressure coefficient on surface of an object in ABL simulation | faiazk | OpenFOAM Running, Solving & CFD | 7 | July 25, 2019 20:07 |
How to manage the pressure term in fixed mass flow rate based channel flow simulation | sjwon1991 | Main CFD Forum | 5 | July 10, 2017 07:21 |
Exhaust Manifold Transient Heat Transfer Simulation | Jonny6001 | STAR-CCM+ | 9 | February 22, 2017 13:24 |
Gas pressure question | Dan Moskal | Main CFD Forum | 0 | October 24, 2002 22:02 |
Hydrostatic pressure in 2-phase flow modeling (CFX4.2) | HB &DS | CFX | 0 | January 9, 2000 13:19 |
