Changing individual cells from fluid to solid in Fluent/Workbench |
September 24, 2020, 13:24 |
Rep Power: 10 |
Hey everyone,
I'm currently trying to model clogging in a pipe caused by particle collisions on the wall. I have seen papers where they implement a strategy of somehow changing cells in a mesh from fluid to solid, and vice-versa in simulating fouling in diesel exhausts. The only problem is, they do not at all specify how they change cells in a mesh from fluid to solid. My only idea at the moment is trying to utilise the DEFINE_PROFILE UDF in Fluent to change the porosity, but I doubt it'll work for individual faces. Is there anyway to change individual cells in FLUENT from fluid to solid, or externally using ICEM and the like? Relevant papers: Development of a Predictive CFD Fouling Model for Diesel Engine Exhaust Gas Systems - DOI: 10.1080/01457632.2012.738321 |
cell types, clogging, fluent, icem, udf customize |
[snappyHexMesh] snappyHexMesh sticking point | natty_king | OpenFOAM Meshing & Mesh Conversion | 11 | February 20, 2024 10:12 |
[solids4Foam] How to calculate drag coeff when using solids4Foam | amuzeshi | OpenFOAM CC Toolkits for Fluid-Structure Interaction | 15 | November 7, 2019 13:50 |
conjugate heat transfer in OpenFOAM | skuznet | OpenFOAM Running, Solving & CFD | 99 | March 16, 2017 06:07 |
Problem in setting Boundary Condition | Madhatter92 | CFX | 12 | January 12, 2016 05:39 |
Unstabil Simulation with chtMultiRegionFoam | mbay101 | OpenFOAM Running, Solving & CFD | 13 | December 28, 2013 14:12 |
