September 9, 2020, 07:30 |
Ansys 2020 R1 Workbench Docking Pane error
Marcos Lindau
Hi.
I'm facing a problem with the software Ansys 2020 R1. My OS is Windows 10. Every time a try to open DesignModeler in the workbench, i get this error: - WB Error while loading the DockingPane. The other geometry command seen to work (SpaceClaim opens normally). After a get this problem, the DesignModeler closes abnormally. I tried already to rename %temp% and %appdata% files. I reinstalled the software many times already, turning off windows firewall. Also registered sucessufully the requested dll's. I identified that the funcionalities of Setup, Solution and results work well, but the Mesh command doesn't work. What should I do? Thanks in advance. |
designmodeler, docking pane, error, workbench |
long error when using make-install SU2_AD. | tomp1993 | SU2 Installation | 3 | March 17, 2018 06:25 |
[OpenFOAM] Native ParaView Reader Bugs | tj22 | ParaView | 270 | January 4, 2016 11:39 |
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch | gschaider | OpenFOAM Installation | 225 | August 25, 2015 19:43 |
How to install CGNS under windows xp? | lzgwhy | Main CFD Forum | 1 | January 11, 2011 18:44 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 17:51 |
