IcePak temperature continues to drop
Old   August 12, 2020, 11:06
Default IcePak temperature continues to drop
Peter Hagan
PeteH is on a distinguished road
Hi All,
I have not posted often, but I do frequent the forum. Thanks for all the great info!
I have an issue with my icepak simulation. While the residuals seemingly converge, my temperature monitor continues to decrease with iterations, regardless of how many iterations I perform. It decreases at a linear rate.
I have an adiabatic cabinet with a rack (geometry macro) heat source placed in the center of it.
Instead of using the CRAC macro, which only allows an intake temperature, I am using a recirculating opening which allows a heat input thermal condition. In this case I am pulling -15000BTU/h from the domain. This seems to be where my issue is, because if I use a CRAC macro and set the intake temperature, the temperature plots become level.
Any help would be appreciated.
Thanks!
PeteH is offline   Reply With Quote
Old   August 12, 2020, 12:37
Peter Hagan
An update on my issue.
It makes more sense to me now that the temperature would continuously decrease in an adiabatic system with the given heat generation inputs.
I added wall material and an external temperature and my solution converges more quickly with a steady temperature.
Unphysical temperature drop when using dynamic mesh peyman.havaej OpenFOAM Running, Solving & CFD 1 June 24, 2020 09:35
High temperature methane+air Peter FLUENT 5 January 26, 2009 19:04
Flotherm-Icepak comparison for electronic cooling Masoud Ameli FLUENT 0 February 28, 2005 10:00
chemical reaction - decompostition La S. Hyuck CFX 1 May 23, 2001 01:07
Temperature in vessel during throttling process Astrid Main CFD Forum 2 January 31, 2001 03:34
