Parameter issue in Workbench - ICEM interface
Old   August 8, 2020, 09:43
Unhappy Parameter issue in Workbench - ICEM interface
VladCFD is on a distinguished road
Good afternoon all,
I am sharing screen shots below to illustrate.
I am experiencing what seems to be a software bug.
I am using ICEM as mesh tool in a Workbench workflow (Design Modeler -> ICEM -> Fluent). I am carrying a parametered study, with workbench parameters leading for instance the geometry dimensions or the velocity at the inlet.
As for meshing, I have already set up one parameter, which appears in the workbench table (cf. pictures). However, when I want to define another one, the parameter does not appear synchronised in workbench.
Moreover, from this point, I can still work in ICEM, but I cannot close it or save it. As well, in Workbench I cannot save the project (saving goes on indefinitely).
I have started the project again, just to end up facing the same issue.
Has anyone been through this ?
I have not found anything related on forums. Any clue ?
Thank you,
Vlad
VladCFD is offline   Reply With Quote
icem, parameter, parameter study, synchronization, workbench
Fluent - Flow/heat transfer over porous media - possibly interface issue ayihan FLUENT 0 March 3, 2018 19:55
Wrong flow in ratating domain problem Sanyo CFX 17 August 15, 2015 07:20
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 07:28
ICEM CFD in Workbench marek CFX 1 February 15, 2008 11:35
Replace periodic by inlet-outlet pair lego CFX 3 November 5, 2002 21:09
