Rep Power: 0 ![]() |
I am using fluent to simulate and analyse a flow past a cylinder. My computer has 8 cores and 16 logical processors. When open fluent, I always run in parallel with 8 solver processes. However, the simulation run very slow and I don't get the speed I am expecting. The task manager always shows that 5-6% of the CPU consumed by cx2010 while each of the 7 fl_mpi2010 consume 6-7% of the CPU. I have another 2 cores laptop which shows that 25% is consumed by the cx2010 while only 2 fl_mpi2010 files consume 10% each. Whats going wrong here and how can I increase the speed of my runs?
Rep Power: 11 ![]() |
Turn off Hyper-threading and use only real cores. Fluent like many other CFD codes don't like Hyper-threading.
UPD BTW 100/16 = 6.25 % - Task manager shows percent of total CPU load. One full loaded core is 6.3% of whole CPU. If you check the total load you see 55% value which corresponds to 8 of 16 cores fluent plus some load for Windows. Last edited by karachun; August 7, 2020 at 17:41. |
Thanks karachun,
How can I turn off hyper-threading? |
From BIOS, check your motherboard documentation.
cfd, fleunt, speed |
Stefan problem using fluent | Isaacibp1401 | Fluent Multiphase | 2 | June 7, 2021 05:49 |
Fluent running increadibly slow | MayTheFlowBeWithYou | FLUENT | 12 | May 22, 2018 02:04 |
Problem with Volumetric Reactions in Fluent | Kashif Rashid | Fluent UDF and Scheme Programming | 2 | December 28, 2017 00:36 |
fluent parallel problem in win7 x64 system | dunga82 | FLUENT | 8 | April 19, 2012 20:23 |
fluent convergence problem | josip76 | FLUENT | 0 | May 26, 2011 20:08 |
