eddy current at different frecuencies
Old   June 2, 2020, 08:29
Default eddy current at different frecuencies
andrea
andrea080690 is on a distinguished road
Theory of eddy current frequency
https://cipca.mforos.com/1357867/130...s-frecuencias/
I am trying to simulate a magnetic field generated from a coil with a current of 150 mA (solid) with different frequencies to detect defects in metal. I have simulated tree defects of 0.5, 1, and 2 mm of deep. In theory for higher frequencies should be well detected defect smaller, like 0.5 mm, and for lower frequencies should be easy to detect deeper defect, like 2 mm, but when I simulate it is it the opposite. I chose maxwell - solution type - eddy current. How could be?
This is the coil on the top of the sample:
coil on the sample
This is the lateral view:
laterale
The field at 1 mm from the sample with a defect of 2 mm at 1 kHz:
The field at 1 mm from the sample with a defect of 2 mm at 20 kHz:
andrea080690 is offline   Reply With Quote
Current density visualisation (PEM fuel cell add-on module) pchoopanya FLUENT 10 August 21, 2023 15:33
[Other] refineWallLayer Error Yuby OpenFOAM Meshing & Mesh Conversion 2 November 11, 2021 12:04
GenerateVolumeMesh Error - Surface Wrapper Self Interacting (?) AndreP STAR-CCM+ 10 August 2, 2018 08:48
How to set current Jendge FLOW-3D 3 November 25, 2014 19:48
What is the difference between current time step and current time djing FLUENT 4 May 1, 2012 17:18
