[FSI]How to continue calculations using other resluts?
Old   May 27, 2020, 22:41
Post [FSI]How to continue calculations using other resluts?
YangSue
513981387 is on a distinguished road
Dear friends:
I have finished fsi calculations of a spring at 0.3mach(Using Workbench). I have got all the Fluent and TransientMechanical data.
Now I want to using the results of 0.3mach as initial conditions, and to calculate the dynamic process of the deformation of the spring from 0.3 mach to 0.4 mach, but I dont know how to operate. I have tried to change boundary conditons in the Fluent module, but when I click "continue update" in the SystemCoupling module, it continues to calculate at 0.3mach
I have tried many times but I cannot set the initial conditions properly, and I need to submit the results before JUNE, so I would really appreciate it if anyone can offer me some suggestions. THANK YOU VERY MUCH!
513981387 is offline   Reply With Quote
fsi, workbench
Help needed! How to continue with 2nd order calculations from 1st order solution? LeoKnight7 FLUENT 4 July 1, 2016 05:15
A algorithm problem meets in the FTC3D code liaoyun0126 Main CFD Forum 0 September 14, 2015 11:24
command TUI / Scheme for stop and continue calculate rayolau FLUENT 1 May 13, 2013 11:20
2D CFD code using SIMPLE algorithm bfan Main CFD Forum 3 June 22, 2002 23:01
EULER-Forward-Method freak Main CFD Forum 4 June 12, 2001 10:19
