I have choose the inflation, but the inflations change in the first layers, but do no |
May 5, 2020, 11:24 |
Rep Power: 10 |
I have choose the inflation, but the inflations change in the first layers, but do not change in the later , what is the reason, who can tell me ?
May 6, 2020, 02:13 |
M
Rep Power: 13 |
What do you mean by "do not change in the later"?
May 6, 2020, 12:06 |
You see the meshes under the red line I drew are all the inflations, but they do not
Rep Power: 10 |
You see the meshes under the red line I drew are all the inflations, but they do not grow according to the growth rate.
May 9, 2020, 05:05 |
M
Rep Power: 13 |
I assume this is ansys meshing. I dont use that, so its just a guess but there might be a global setting for the boundary layers somewhere which overwrites the values you gave here?
I'm thinking like there might be a minimum layer height defined somewhere. Now if it starts from there and uses the growth ratio you specified, it reaches your specified max height earlier and its then constant for the upper layers? |
May 9, 2020, 10:55 |
You may mean the maximum layer height? What do you use for meshing?
#5 | |
Rep Power: 10 |
inflation layers for hexa mesh using icem cfd | Apple | CFX | 4 | January 6, 2012 01:12 |
Large Valve Flow Analysis - Inflation Problem | sercan85 | ANSYS Meshing & Geometry | 2 | June 1, 2010 15:02 |
Inflation layers / boundary layer meshing. | andy2o | Main CFD Forum | 3 | February 22, 2009 10:03 |
Creating inflation layers for elbow with airfoil ! | Aplus | CFX | 1 | March 13, 2006 23:22 |
Inflation | Gab | CFX | 6 | August 24, 2005 23:45 |
