how to get proper points location of geometry in CFD Post?
Old   May 4, 2020, 16:59
Default how to get proper points location of geometry in CFD Post?
teguhtf's Avatar
teguh hady
teguhtf is on a distinguished road
Dear all,
I am simulating transient heat transfer of water in Coil Tube by Ansys FLUENT 17.2. I want to take some variable in CFD post in such as Wall Heat Flux and Temperature on tube wall perimeter (interface between tube and water). Because of complex geometry, I make points coordinate of the perimeter from space claim and I manually type them to excel .csv then I import the csv into CFD post. However, the plot graph in the cfd post the graph is scattered and not good (it seems points not in the proper location but when I check in the space claim the coordinate is correct). Then, I decide to pick one by one by using probe in CFD post but due to many points location in geometry and the value is good, using probe is so wasting time and tiring way (however by using this methods, I can not manage proper location every point on the perimeter of wall). I also make point (based on coordinate in space claim) in FLUENT in Monitor parameters and save them every time step but the value is not good.
Do you have way to get proper point in CFD post?
Thank you
Teguh
Now Or Never!!!
teguhtf is offline   Reply With Quote
heat transfer, perimeter line of wall, points location
Post processing journal - like .cst in CFD Post Jiricbeng FLUENT 0 April 24, 2019 09:08
CFD Post Streamlines better representation? Dr. Flow Squad CFX 2 January 20, 2014 14:48
Importing geometry from solidwork to ICEM CFD sahil sharma Main CFD Forum 7 September 2, 2012 15:01
CFD Post: Location of maximum and minimum velocities! JuPa CFX 6 August 31, 2012 10:51
Poly lines in CFD Post ashtonJ CFX 0 December 2, 2010 03:46
