April 15, 2020, 19:33 |
Simulating post-stall results
Jesus Roman
Hi all,
I am conducting a project about the aerodynamic effects on different elading edge geometries. I have two 3D models (wavy and sawtooth leading edge) which I am simualting in ANSYS Fluent. The results for the baseline wing does not match already existing results in post-stall regions. How can i obtain the correct results for this situation? Model: SST k-omega Re = 2e+05 y+ ~ 1 Boundary conditions in 3D C-grid: v-inlet, p-outlet, symmetry (in lateral faces), p-outlet (in top and bottom faces) Thank you. Jesus Roman |
fluent - parallel, post procesing, stall control |
Problem: Cannot get Results to work in post processing | mattsarg55 | Visualization & Post-Processing | 0 | August 5, 2019 11:50 |
Results for wall temp in fluent are different to wall temp in CFD Post, Why?? | jonheb | FLUENT | 1 | March 6, 2018 11:48 |
cfd post results | imthiyaz | FLUENT | 0 | September 25, 2016 10:49 |
wind turbine simulation, Ansys Post results question | Laions | CFX | 7 | September 20, 2011 06:13 |
Adding results in CFX 11 post | Dimitri | CFX | 0 | February 5, 2008 05:28 |
